won't  start. I have checked out all electrical components, changed ignition, sensor shift indicator (wires  partially broken off), starter relay, ignition coil, checked for broken wires, none were found.  Fuses good
won't turnover, took out ECU, and EFI but still getting neutral on display.  key bypassed by machine. Had it running once but nothing for the last 2 weeks.  When running no reverse indicated on display.
  • Confused 1
    • By Rschrem
    • By Tim n Deb
    • By KWinTX
    • By Some random dude
      2015 Hisun 700 Utv
