I'm not finding one anywhere..... you might contact cub cadet and try to figure out who made the transmission. I'm almost certain Cub cadet didn't build the trans. Probably Spicer/Dana, or Tuff Torq.
  • Popular Now
    • By Rmillerdesigns
    • By mark walkom
    • By Jacob E freeman
    • By Hisun .500
      So my hisun 500 is tore up and all the wiring is wasted i was wondering can i pull out all the wiring and just put in the. Basics .please help
    • By Ken kushner
      2017 stampede eps pulls to one side at idle and while driving any ideas
      Ken
