Has anyone come up with a replacement besides Joyner ???
Mine started squeeling the other day and I figured I better get a backup.....
Can't find a 4 rib that matches so far....
Kurt G
take the number to a auto parts store they will know what to make of it. it starts 040... the 4 means 4 v's then the last part of the number is the total length like 275 would be 27.5 inches.
hope this helps.
    • By nrggaragebuilds
    • By OBL
    • By Bucky4444
      Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
