Anyone know of a product that will help reduce the amount of dust that sticks to the windshield? Like rain-x for dirt? :P
Dust buildup is a big prob for me on these desert trails, I currently have a 3/4 window setup and may have to hack that down a bit (last resort) if I cannot come up with another solution.
Rain-X is suppose to help. Sorry, I just clean it for a day on the trails and LEAD when possible. Carry some cleaner with you and clean it during the day.
rocmoc n AZ/Mexico
If your windscreen is acrylic don't use rain x. Kinarfi said that he used Pledge on his Air craft windscreen, it is also used on boat windscreens made of acrylic over here and is the way to go along with Gumballs answer above.
Cheers Mike.
    • By nrggaragebuilds
    • By Blekntowkz
      Any advice would be huge.
    • By AaronD1982
    • By Fmaxiron
      Thanks a lot!
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
