Annoying squeaking...is it the brakes?
So my Coleman since the day we got it has this annoying squeaking sound when moving along slowly ,  its sounds like it 's in the front and the back, but not sure if its just the sound carry along the botton. If you apply the breaks  it gets louder, go up to speed and the noise goes away. It sounds like the breaks , but I can't see anything., its metal on metal sound, I'm  just clueless as to what or where. Has anyone else had this issue?  if so do you have a fix. If not does anyone now what it is?  I'm trying to load a video, if successful , you can hear the sound, along with my comment that's it the breaks, but I really have no idea, The important thing is you'll be able to hear the sound , I would appreciate any advice or guidance on the fix.  Thanks
Drum brakes i'm assuming?
jack up the rear end (and take it out of 4WD if equipped) and see if it makes the noise with the rear end off the ground. if it does then its probably your rear brakes making the noise.
how long ago did you buy the machine?
There are actually 5 disc brakes on these machines. 1 for each wheel and 1 on the rear driveshaft for the parking brake.
I've read several complaints of the parking brake one being too tight from the factory so I would check the cable and make sure there's a little slack when the parking brake is released.
If that is good I would jack up each corner Individually and spin the wheel to listen for noise and feel for dragging. That should help pinpoint where the issue is.
  • Like 3
Thanks for the response!!   The machine is still new , we have about 6 miles on her. We bought her to take out to the lake  last year, finally got around to it .
Thanks, next time we are at the lake I'll check this out....appreciate the response.
I was under the rig playing today so I decided to adjust the parking brake just to make sure it was ok, since I've read a couple people having them adjusted too tight from the factory.
First picture is the parking brake disc & caliper from the passenger side. Second picture is the adjustment bolt.
How it works: it's a cable operated disc brake with a locking pawl to hold it where you push the pedal to.
Procedure: The pad tightness is adjusted by moving the bolt in the 2nd picture in and out. When you tighten it it pushes the pads together. The extra nut on it is a lock nut.
Using a 13mm wrench loosen the lock nut. Back it off about halfway just so it's out of the way. Next tighten the bolt by hand until it stops. From there back it off about a half turn. Push the parking brake and make sure the pedal "locks up" before running out of travel. If it doesn't adjust the bolt slightly tighter and try it again. Once you're happy with the adjustment tighten the lock nut while keeping the bolt 20220715_153255.thumb.jpg.e66ac077bfb4436eaf94b0250a6c6d8d.jpgstationary.20220715_153305.thumb.jpg.bb8132472b5366a9581e82bb8e097ef3.jpg
good stuff thanks ! did you find it tight, or was it ok on yours
  • 2 months later...
The parking park was fine with mine, but backed it off just a tad anyway. What solved the squeak  was  I was removed the wheels one at a time , turned the soleplate by hand and found that the front left ( drivers side) one squeaked . I loosened and re torqued the  hub nut and sprayed brake cleaner to clean any debris  and the squeal stopped and has not returned. Thanks everyone for their help and input! This pic from Robert B helped
  • 4 weeks later...
Similar issue on my 2022 Coleman Outfitter 550 where the parking brake was locked up.....parking brake pedal would not automatically release when applying brake.  I had to adjust the tension on the cable release that runs from the brake to the parking brake pedal (located on the other side of the floor panel behind the parking brake).  I then adjusted the parking brake pads per the procedure mentioned previously.  If you can't easily push utv with the parking brake disengaged-you know you have a problem.  By the same token, if you can push the utv with the parking brake engaged-you also have a problem.
  • 7 months later...
I have a 2021 UTV400 and when I purchased it recently it made no noise. I get it home and a couple days later I hear the same squeaking as in the video posted by Rob, seemingly coming from the back. Now I hear it all over, as it's getting worse. Looking at all the rotors, brakes and parking brakes, they look like they're grooved, but when feeling them, they are smooth with little to no feeling of any indentation.
At first I thought it was the parking brakes, but when released, I can easily push the UTV, although the e-brake pedal is high with little travel when applied.
Good stuff here, as I will have to check all the brakes and adjust the e-brake. Hopefully I can pinpoint the problem, as I mentioned, it's getting worse.
Using a 13mm wrench loosen the lock nut. Back it off about halfway just so it's out of the way. Next tighten the bolt by hand until it stops. From there back it off about a half turn. Push the parking brake and make sure the pedal "locks up" before running out of travel. If it doesn't adjust the bolt slightly tighter and try it again. Once you're happy with the adjustment tighten the lock nut while keeping the bolt stationary.
Good info, but I'm not sure which bolts in the second picture you are referring to. I think I need to adjust my e-brake because the pedal doesn't travel much at all when applied and I have squeaks that sound like they're from brakes and coming from all over. Need to check them all, but want to start with this. If you can clarify which one of the bolts is the adjuster, I would appreciate it - thank you.
  • 4 weeks later...
I had jacked my rear up and tried spinning my wheels and there was a bit of resistance, as well as the wheels not spinning as they would on a car. Took the wheels off and tried spinning the soleplates and it was really hard to turn. It this normal or could the hub nuts be too tight? On vehicles I've worked on, wheels spin easily, but I know this is a different animal, something I've never worked on. So with that said, should the wheels/soleplates spin freely with many turns?
This is all to to me as well, I can't say I know the answer to that, wish I did though. When I turned the soleplate I noticed the squeak. I did like I said and noticed the squeak went away.  At that point I was happy and unfortunately I didn't really pay attention to how freely it spun. I am going to need to do some maintenance here soon as I'm starting to hear the squeak again, its not as bad , but its there. It could be just in need of some cleaning.
so just got our ut 400-rt notice it was squicking and felt a drag, also notice if i part on a small hill it will roll either front or back, with  parking break set or release, (there fells no differents between brake on and brake offf, now looking up front  when you press the parking brake you can see the cable move up front but at the drive shaft caliper (were parking brake is it doesnt move any thoughts whats going on with parking brake?
[email protected]
    • By BOYD
      I have a 2004 KUBOTA RTV 900 DIESEL and I need to replace both front cv axels.I have been online looking at them and there seems to be a lot of different manufactures to choose from. My question is who makes a good aftermarket set of cv axels for this KUBOTA. I have read horror stories of people buying the  cheap Chinese brand only to find out they don't fit or they don't last very long and fail again. I hate to have to spend over $200 a shaft to get OEM from KUBOTA when I'm sure there is a company out there who probably makes it for them or makes comparable to OEM. Thanks for your help.
    • By wnc woods
      Is it possible to add a low gear to the Coleman ut400? If so please help. Ty
    • By Mark M
      Hello, Hope someone can help driver side cv axle broke anyone know of aftermarket ones you can get, I have 40 Hours on the machine and don't want to pay 450.00 for a new one from cub cadet but I can't find anything after market
    • By buckrub
    • By MOTORHEAD1959
      ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
