2016 Mule 4010 - Overloaded Payload, now Mule won't go fast & lacks power
Go to solution Solved by cliffhodges,
Hi All- Long time reader, first time posting.  I have a 2016 Mule 4010 (model: KAF 620V).  I am having an issue since overloading the payload a couple days ago (yes I'm a dummy).  I live on a very hilly property and I was trying to move some large oak rounds for firewood splitting.  I put WAY too much wood in the bed and when I started driving, it sputtered, kicked out of gear, and then cut out.  I unloaded all the weight and started it again - appeared to be running fine when idling and/or driving on flat ground at slow speed.  But when try to go fast or uphill, the RPM's rev high and it sounds like the motor is fine, but it has ZERO speed or power at all (literally creeps uphill at like 2-3 mph and won' go faster or take any weight), and has no power at all.
Other info: 3 weeks ago I did a belt replacement.  So I was worried I perhaps screwed that up somehow. But I just opened the clutch housing to check and the belt and clutch appear to be working just fine.... sooo.....
Any ideas what I screwed up by overloading payload and immediately trying to drive uphill?  Any tips would be greatly appreciated!
the 4010 does not have a wet clutch.
One thing that comes to mind, i would check the rear axle splines. the hubs are splined to the axel, if those splines pullout, or strip, it could cause a low speed issue like you're having. you should be able to check this by remove the rear tires, and axle nuts.
it could also be an issue with one of the drive pulleys not fully engaging, This is the first thing i would do, remove the belt cover  and make sure the pulleys move in their full range of motion.
Posted (edited)
Go back and check the drive belt again, it is most likely slipping.
I have pulled a tractor and pick-up out of mud, I have loaded the the bed with as much firewood, as it would hold, I have drug 24" diameter and 10' long logs.  I have driven up  inclines so steep my truck had to be put in 4x4 low.  In a1998 2010, and shredded the belt once in 2008.
I am a bit tough on equipment, and a K-Mule is the toughest vehicle I have ever owned.  And I had a WW II JEEP.
Edited by Azul
Add more info
I dont need to check in under load because the problem perists regardless now. It started because of a heavy load, but now the problem happens whenever driving, load or not.  So I'm wathcing the belt as I drive - I've got the bed tilted up and the clutch housing off, so I can look directly at it as I drive. Not slipping.  I'm totally stumped.
  • Solution
In case anyone is following:  we finally diagnosed this issue.  It was an ignition coil.  Pretty much fried out under the heavy load.  Was not the belt (or the wet clutch as the mule doesnt have one). Thanks everyone for your time and input!
    • By paul allen
      thanks...pa
    • By Sidewinder
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
