My Trooperf has been sitting for a while and the other day when I started it, it smoked a lot, then today when I drove it around for a while, it quit smoking completely.
Any body else noticed this? Any ideas?
Kinarfi
Kinarfi
Trooper smoking! I knew you just installed the muffler I brought up to you. That got me thinking, Oh darn, I knew I would forget to take out that bag of weed I smuggled in, inside your muffler. Did you say that Linda said that was her funnest ride yet. Hummm, you have any thoughts as to why that was.
Yes they do have valve guide seals, you can tell when they are out by going down hill with your foot off the throttle, or when you have alot of vacum, when you step back on the throotle it will smoke untill it cleans out. Maybe you are lucky and your crank case valve (pvc valve) stuck and was letting the intake pull oil out of the crank case.
Took it out for a ride and when I got back and ever since, no smoke, must of been that stuff Lenny left inside, must have been two bags in there and I missed one of them. :lol::P:blink: Or maybe it was all that sitting and only occasional runnings for short times. Naaaa it was Lenny!!!!!!
Maybe the Harley it came off of left it full of oil. Who knows?
Kinarfi
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Rmillerdesigns
    • By jugliner
      I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed.  It has been sitting for 2-3 months and was fine when parked in garage.  I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up.  I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter.  I've also checked the spark plug, Still surging.  I reset the ECU after every component swap.
      I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
      Any suggestions would be appreciated on next steps.   The problem developing after sitting makes me think it should be something simple, but I'm stumped.  BTW the fuel was fresh and treated with Stabil.
      Thanks.
    • By Recon Marine
      Ran fine parked it in garage and 5 days later would not start or make any noise trying to start. Bought new battery, installed it and still nothing, no noise or anything.
      Any idea? I can’t figure it out since when I parked it, it was running great.
