Coleman Outfitter 550 Fuel Injectors
Popular Now
By Dave Jones
So with seat belt on I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
By Mitch13
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
By RBonds007
By MilSurpYinzer
Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
Vehicle is a Kawasaki Krx 1000
I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.
By Rmillerdesigns
