CHery Engine info
By HISUN Sector 750 EPS Failu
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
By J Cardwell
2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
By oakhill
When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal. It also is not idling very well. Both symptons appeared at about the same time. What should I look for? Thanks.
By Dewayne jones
