Anything can be done with enough time and money, but it's totally unnecessary for a small engine. By the time a piece of the engine large enough for a filter to worry with gets in the flow, the damage is already done. There's a magnetic trap that collect very small metallics and this should only occur during break in.
So the function of oil filters in small engines is to catch any junk that is inserted into the oil by sloppy oil change or other maintenance procedures. Don't put junk into the oil fill tube and you don't have to worry.
My Axis 500 has a remote oil cooler attached to radiator. Metal oil lines from engine, up to top of radiator, then rubber hose from there into the oil cooler. If the Massimo is similar guess you could add a remote oil filter from those hoses.
On 1/9/2024 at 11:25 AM, T-boss 410 said:
Gotcha! However, I have a twin cylinder Briggs and Stratton engine on a riding mower that is equipped with an oil filter. Why would this be different?
Thats a better engine..lol
I don't believe there's a remote oil cooler, so I would have nothing to attach the oil filter to.
    • By Aaron Colona
      Just bought a brand new 760 about a month ago. I'm at 20 hours which the book says is when you need to change the break in oil.
      I must be crazy, but I can't find the oil filter. I've googled a million videos...everything seems to be 2019 or lower...and/or a 550.  They all show the filter easily seen by looking in past the rear passenger tire on the engine. There is absolutely nothing there on mine.
      1.there seems to be very little info if you Google a 760, or anything Massimo newer than like 2019.
      2. Does anyone have a current model year 760 that can answer my riddle for me?
    • By Grant
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
