BANG IT'S DEAD -MAYBE
By great8redsfan
By tim hughes
does any one else have a slipping belt on the hisun ...i put new wet clutch one way bearing new belt, cleaned primary and secondary and still get slight slippage
By Richard shepard
I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
By Timpiker
My UTV is a few years old and gets very little use. I just noticed the drive belt slapping the plastic guard and making some noise. The manual tells me how to replace it but not how to tighten it. Apparently, there is no adjustment. Does anyone know if there is an adjustment? Is the belt supposed to have a lot of slop in it?
By NewtoUTV
I have alot of issues with this machine that I'm trying to figure out and fix. Today when I was fixing the shifter I see this cable connection that is not connected to anything. I looked and can't find where it might need to be. Any ideas would be greatfull.
