So cut some metal squares from scrap or go to Lowe’s and pick up some metal sheets. Just like above rivet or bolt to add support to those areas that are cracked. The bigger area you cover the better. Do it from the bottom to make it look more professional. Probably not great to haul firewood in the plastic bed. You might also look into a metal sheet to cover and add support to the entire bed.
My past job experience we “scabbed” vibration conveyors using the metal squares with great success.
My Coleman (Hisum) bed is plastic.  It has taken a lot of abuse from firewood both rounds up to 18",  and spits tossed into it from several yards away.   Knock on wood, it is holding up OK, but I know that the Asian plastics can become unstable over time and brittle.   We'll see.
Many of these work beds are gas shock supported.  But if you get close to 500 lbs in the bed, its a chore to dump. Once the logs start to roll off, it pops right up.   Not sure how long those gas shocks last though.
Looking again at the pics it almost looks like something was attached to those eyelets and maybe jerked under load, fracturing the plastic they are mounted to.  Just a guess.
I looked up his UTV..it's nearly identical to mine except 50 hp to mines 39.bed appears. Same size..I Have loaded mine to capacity and it took 2 of us to lift. Can't imagine trying with double that weight piled on. Towing 2000 lbs  I. get ,cause my 500 can tow 1500 but half ton in that plastic bed?dicey
I've had it loaded with firewood on many occasions.  The bed has a piston to assist it in dumping so it wasn't that hard.  Just needed a little help.  The cracks most likely happened when the bed warped from the engine heat.  I put a heat shield over it, so will see how it goes.
On 15.05.2024 at 23:15, NHTracker said:
Mam Trackera 800SX LE z 2020 r., którego kupiłem nowego w 2020 r. Wczoraj zauważyłem dwa pęknięcia w skrzyni ładunkowej na wewnętrznych rogach przy końcu tylnej klapy. Przechodzą przez całą długość. Używam go na posesji, przenosząc drewno opałowe, brud i inne rzeczy. Nigdy nie obciążam boków skrzyni ładunkowej. Czy ktoś inny miał ten problem? Czy jest jakieś rozwiązanie? Pomocy!!!
shitty plastic you need steel bed
  • Haha 1
    • By MilSurpYinzer
    • By Eman85
    • By RBonds007
    • By Xov
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
