Beryl
By rdc
By Rmillerdesigns
By KMP
We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT. We are truly beginners and welcome any and all suggestions. Thank you, we appreciate your help!
By malenurse13
We bought a used American Landmaster TW450 with a Fuel Injected Kohler 440 on it. Today, I bought a Predator 459cc 15.8hp motor from Harbor Freight. But before we put the new motor in, it's pretty obvious, the stock throttle length is NOT long enough. The stock throttle cable from gas pedal to the end is only 32 inches!
We need at least another 10-12 inches to get to the throttle linkage on the new motor. What can we do??
Is there some way to modify the original throttle to add some length? Or do we have to buy a brand new cable?
