After all the work and help from the forum I took the Trooper out for a serious test ride.
Everything worked great. The new front suspension soaked up the trail like a sponge. Any concerns about fender clearance were dispelled and they took some heavy abuse through pucker bushes without any problems.
The next test will be 5 days of riding coming up later this month.
Thanks again for the help given by the Forum gang.
Gumball
Gumball
Glad to hear you are out riding,, have fun, be careful..Quig
  • Popular Now
    • By paul allen
      thanks...pa
    • By MilSurpYinzer
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By Kyler
      Put new fuel in this thing, new battery I can get it to turn over but want stay running it’ll try to run with starting fluid but shuts right back off what could the problem be?
