I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
