Trooper Viper Custom Camshafts
By Outlaw Redneck
Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando, I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
By Rowdydog
Hi, new to forum but not new to off-roading. Am retired and looking forward to seeing some country side in my RZR XP Turbo. I recently added some 32 inch tires, not exactly monster tires and I know I have the power for most trails, but do not want to sacrifice the approximate 10% power this added wheel speed will cause. So, thinking about putting in a 12% reduction set. Just asking if anyone here on the forum has installed their own reduction gears and how long does it take? I am sure I can do it, but some things are better left to the experts. I have been a gearhead most of my life and turned wrenches for the better part of it, but actually a little tired of the busted knuckles and such. I should just let someone else make a living at it. Any thoughts from someone who has performed this?
By Jarheadtx
I have a 2020 Sector E1. It's been a great UTV over the years and I did a lithium battery upgrade a few years back (complete game changer). Since owning the unit the dashboard and lights would occasionally flicker while driving, but not every time. I couldn't replicate the issue in any driving scenario and all fuses are good. The dashboard and several switches finally died completely this past weekend - meaning lights, winch, and dash lights do not work, but forward/reverse and speed work. I rechecked the fuses and all look good - any ideas on what else to check?
By Tommy2bits
Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
