Electric 4x4 locker failure question
By donwan
View File 2017 Hisun Strike 900 Service Manual
Here's the service manual for the 2017 hisun strike 900.
Submitter donwan Submitted 05/29/2024 Category Hisun
By Buddee
Any help appreciated!
By buckrub
By BuggyBoy
Hi,
I'm in Australia and need to replace the footbrake pads and cable (weak point if you ask me, bad design), plus might as well get the main brakes done at the same time.
Anyone know an Aus dealer, or, know the parts number or equivalent in the petrol version?
Cheers.
By Randyh79
