Hey everyone I'm just curious what year troopers are out there and how many miles u have on them when did u start seeing big issues and I don't mean wheel bearings and such! I mean motors tranny frame cracks so on
Mine is 09 with roughly 2000 miles on it...i have broke a rear swing arm,
1200 miles the fusebox went bad and kept blowing fuse to ecm.
Now 2000 miles...both my front wheels toe out especially badly on passenger side when steering wheel is straight passenger side wheel points out and away from trooper. I haven't looked into why that's happening.
I haven't gone under the trooper to look for any cracks since it's pretty much coated with dirt and mud and gravel dust under the trooper lol *knocks on wood*
2500 miles mines 09 no major problems yet. dedub. turbo going on as we speak.
I want/NEED turbo but funds don't don't allow for that right now, the outlaw 2 are 50 lb each and i can't drive in 4th gear that well or get past 45/50 mph
Nice!!!!! How was the power was the acceleration what u thought it be
yes lot more torque. not much on big in thats i went with small charger spin up quick. i've not got on big hill yet.
Really i thought 7psi would be good boost with extra power....what size turbo are you using?
not shore the number inlet 1.78 out let 1,50 garret.
13,417.9 kilometers and I have been working on it continually, but not necessarily because it needs, I just enjoy doing it and I don't have anything else to do with my time, can't work, so it is something to keep me sane, sort of.
    • By Tim n Deb
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By KWinTX
    • By GunnersTacklebox
