looking around and cannot find and Stampede motors, the Havoc looks to directly bolt in, with exception of the larger displacment. has anyone looked into this further? seems to be a better option considering stampede engines are on backorder.
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in. It still acts like the belt is slipping but now I am thinking it is the clutch?
Can the clutch be rebuilt?
