Going riding and going to get RICH
Got a metal detector for Christmas. Wanted a nice one all of my life. Now my riding trips will be twice as fun. Going into the mountain foothills along the eastern Navada boarder about 25 miles north of Utahs southern state line. This is gold country so we will be looking for nuggets. Actually won't get rich but its all about the thrill of the hunt. Who really knows, somewhere in this world is a 25 pound nugget and someone just might find it. The trails are going to be good and and with my heaters, the Trooper should be comfortable dispite it being in the 30s. No snow.
Well, I'm not rich yet. Had a great time. Rode up to elevations where it was 15 degrees and we were still comfortable and warm. I got a Minelabs.
How about looking for other precious metals along with gold those are in high demand these days i hope u get lucky
I'll take anything I can find. Maybe I'll be able to pay for my gas to get there.
ooohhh, you got the good one!
I used the heaters and fans from the heaters that Joyner put out for the Troopers. Doubt you can get them any more. The radiators are about 5" by 11" and about 1" thick, each with two computer type fans hooked to them. I mounted one under each seat on the vertical wall behind your legs. I also used a three way valve for the hook up into the engine coolant system. This way I either run the coolant through the heater coils or not. They work great. Having them under the front of the seat is perfect because we carry a couple of blankets that we throw over legs and the heat comes up under them. Its amaizing just how cozy it is even in quite cold weather. We don't have behind the seats colose off not the top halfs of the doors but we do have a windshield that can completely close off the front. If your looking to do somehting, the 12 volt computer fans work good. I would look for a couple of heater coils out of a car or maybe a motorcycle.
For those who want to do heater i imagine an mini micro radiator for very small atv or like that could be made to work like a heater core or we could get a actual heater core from pick up and make that work
  • Popular Now
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
    • By dryvalleyboy
      The steering shaft is slipping,I checked it's tight as the bolt will take at the u-joint.. Is there a slot or something it may have jumped? This is right after the shaft enters the area under the hood.Thanks.
    • By old fart
      Trying to find battery size for 2023 750 eps secter, wqantedd to see if any one had in stock as we live outside of town. Seems like it's a highly gaurded secret.
    • By Edelbrock
      Nice Offroad rig.
