One thing you can do is to replace the steel plates under your seats with an aluminum plate. This will save about 10 pounds. Eliminating the front 2 piece drive shaft with one piece of DOM tubing will save about 20 pounds. This eliminates that extra heavy center bearing assembly and 4 u-joints. Just cut the spleens off the ends of the stock drive shafts and weld them to the one piece shaft. You then meed to align the transmission output shaft with the front differential shaft. This is done by shiming under the motor mounts. Its already quite close to begin with. You can save an other 4 or 5 pounds by cutting out the solid lugs that connect the roll bar to the main frame. Just lower your roll cage and weld it solid. The seats are heavy and there are ones available that are 1/2 the weight. This can save another 40 pounds. I run 15 inch rims and by shopping around, I found rims that weigh about 10 pounds a piece. The first ones I had were a typical 20+ pounds each for a 15 inch. That saved me about 45 pounds when done.
Leave your spare tire behind but better carry a cell phone. Replace the radiator with a lighter better flowing one. The Stock one is super heavy.
rocmoc n AZ/Mexico
    • By Eman85
    • By hetovi
      Hi everyone,
      I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
      I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
      Are there specific brands or models you recommend for durability and ease of use?
      Also, how do you handle cleaning and maintenance without causing damage?
      Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
    • By Red Good
      I have a massimo 500 with a blown motor and want rid of the rest of it . Is that ok here ? Motor is in a box , has low hours on the machine be a good parts machine for someone or stick a  different motor in it . Tires are good body looks like no use on it . 500 bucks takes it away  . 918-479-4200 located in NE Oklahoma .  Red
      Any thoughts ?
    • By Pilot1996
      When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
