S-10 blazer
By jugliner
I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed. It has been sitting for 2-3 months and was fine when parked in garage. I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up. I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter. I've also checked the spark plug, Still surging. I reset the ECU after every component swap.
I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
Any suggestions would be appreciated on next steps. The problem developing after sitting makes me think it should be something simple, but I'm stumped. BTW the fuel was fresh and treated with Stabil.
Thanks.
By Christian Chenier
Hi,
I've just completed my first summer with my Sector E1. Great machine so far. I know I will eventually replace the OEM dry cell batteries with lithium but I would still like to make them last as long as possible. Are there any tips on winter storage while the vehicle sites unused? I assume keep them fully charged but other than that?
I live in Canada so temps can get very cold.
Chris
By Bandman
I have a Cyclone 4115 Toy-hauler with the HappiJac couch/bed lift that doesn’t fold agains the wall so I am limited in vertical height. I really like the 1000-5 SE that’s 76.3” tall and the measurement to the bottom bracket of the couch is 78 3/4” so the numbers seem right. is there something I’m missing? Is anyone transporting with similar equipment?
Thanks in advance,
By Travis
It''s sleeting here now, though the radar just shows rain, looks like the rest of Texas is going to get snow too. it's 37° right now.
By 2483Deer
Custom fully upgraded toy hauler. Completely foam insulated, exterior plug in for led lights, plugs, and accessories. Fold down queen bed, tons of cabinet storage, and tool box in V-nose. Fully wrapped galvanized roof, 4000 lb ramp dr, upgraded 5200lb axles, 7 star alloy wheels. 16' retractable awning, added 18" to standard height. Electric brakes "both" axles. Interior finished in FRP board and floor line-x for easy wash out, and grip on ramp. Perfect for camping with four wheelers, and side x sides or a weekend at the tracks. I am the original owner and custom built it myself. My kids and I have camped in 7 degree winters to 100 degree summers. Perfect for all seasons.
https://smd.craigslist.org/tro/d/dunkirk-custom-85x20-nose/7223331105.html
