did any body else get email from silverbullet
By UTVLover253
What you love about it
What frustrates you
If you're open to hopping on a casual 30-minute Zoom or phone call sometime this week or next, I’ll send you a $100 gift card as a thank-you.
No sales, no pitches—just listening and learning. I'd also just ask that you send over a photo of you and your side-by-side in action (nothing formal—trail pics or selfies are totally fine!).
– Adam
By Alien10
By hdtran
By sxr951
