Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
We've got the old Kohler motor out and the new Predator 459cc in!
But before we put the motor in there. I took some pics of the old wires. I'm hoping y'all can help me figure out what all these are for and what we need to keep.
There are a lot of inline fuses. And all the labels we can read say "12v pos" or "regulator/rectifier."
Main thing I'm looking for:
1. Wires to connect the stock ignition to the starter on the new motor
2. Wires for the headlights
If anyone can help me identify what all these wires are for, I'd appreciate the help!
I have a 2020 Sector E1. It's been a great UTV over the years and I did a lithium battery upgrade a few years back (complete game changer). Since owning the unit the dashboard and lights would occasionally flicker while driving, but not every time. I couldn't replicate the issue in any driving scenario and all fuses are good. The dashboard and several switches finally died completely this past weekend - meaning lights, winch, and dash lights do not work, but forward/reverse and speed work. I rechecked the fuses and all look good - any ideas on what else to check?
It looks bad, but the HISUN (Axis) 500 at work has had "regular" oil in it for 900 hours now. I discovered it when I googled what my Sector 750 uses, it being about time for the first oil change. This is the only side by side that the mechanic at work takes care of, and he's the type of person who knows it all. He would never check an owners manual or search something online.
The problem with someone who knows it all is all you get is what he knows.
Being on a first-name basis with the HISUN Tech Team, I've asked them what the consequences might be. I'm concerned that the clutch may be permanently damaged.
Anyone had this experience?
