Hisun fuel tank vent problem!!!
By Rschrem
By monkthumper
By BigWave
Bigwave
By Ed Michael
My older LM 650 is blowing fuel into the air cleaner. Any idea on what would cause this? It is the Suzuki motor. Not sure what model year it is.
Subaru SxS.mp4 -
By Mike Jenkins
I replaced the stator and now it will not start (run). It cranks fine, has fuel pressure, but will not fire up. I replaced the coil, no luck there.
