Put 32" IPT ultra cross r spec on my trooper. They great tires on the slick rock no balancing needed. For now I used a big hammer to make them fit,  but will do something cleaner in the future.
  • 5 months later...
  • 3 months later...
    • By RBonds007
    • By Outlaw Redneck
      Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando,  I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
    • By CKfrustration
      I have a Hisun Sector E1 UTV.  Worked pretty good for a while but then started to run into issue with gear grinding noise.  Will not engage in forward or reverse.  When put into forward or reverse and press pedal can hear a whiring noise as if something is supposed to be engaging but is not.  Occasionally it will grab in jolt forward momentarily but then ceases.  No error warnings or codes given.  Due to money restrictions, I really need to fix this myself.  Has anyone had this problem and what could it be that is needed.  Any help is appreciated.  Thank you!
    • By Recon Marine
      Ran fine parked it in garage and 5 days later would not start or make any noise trying to start. Bought new battery, installed it and still nothing, no noise or anything.
      Any idea? I can’t figure it out since when I parked it, it was running great.
