My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
I’m ready to buy a second machine. I looked at a Gator and a Mule. They are larger than I want. Something more trail size will be better. That being said, I do not wish to purchase from a big box store again. Can anyone recommend a good dealer who sells Hisun based machines?
Also, any thoughts on a machine with enclosed cab, HVAC, and modern electronics
Pop Bob
I have a 2011 or so Landmaster LM200. I cannot get it to start. I turn the key and nothing happens. The brake switch seems to be working, the ignition switch works. The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine. I just can't get it to start by turning the key.
