On 9/1/2017 at 8:15 PM, nybuckboy said:
Anyone know how I can upgrade the lights on my 99 2510 Mule ?
If you're thinking of adding more power to the existing headlights, you're likely out of luck, without extensive modification. But I'm no expert.
  I'd recommend a light bar. They've got some really nice aftermarket stuff out there. They come in all sizes and shapes. Installation is usually plug n play.
At 120w of power consumption, it'd have to be used only while the engine is running. Just for comparison, my mule 3010 has 50w stock lights, and they don't perform well either. That thing would pull the battery down in just a couple minutes, possibly leaving you stranded. I'd suggest splitting up the task, if you want heavy duty lighting. So you've got to figure out exactly what you want to accomplish. Are you just lighting the trail in front? To the side also? To the rear? Are you lighting the cargo area also? A work area light
    You'll need a heavy duty rocker switch panel, and several smaller lights, or bars. I'd run em through an additional fuse box. I'd also suggest upgrading the alternator, if it has one. And maybe adding a back up battery.
    This way you can turn on only what's needed. The  job would be cleaner from a maintenance/trouble shooting aspect. And the effect would have a much better cool factor, IMHO.
   Upgrades like this can be expensive. The easy solution is to just get a couple of forward firing led lights. Our Toyota forklifts at work, have what you need. Check out the newer models of these locally, or on the web. They aren't powerful enough to replace the stock lights, but to supplement the total.
I can also tell you that the color of light is important, to actually recognize what you're seeing. Led lighting CAN do it. But the technology has barely made it to the flashlight market. Extremely white light gives a washed out appearance to stuff. You want a more yellow light. It's a huge difference, but you have to see it firsthand to appreciate it.
13 minutes ago, Travis said:
I thought about getting one for my 550, but they are $800!! Plus, its just another  thing to break!
You'd need one with an air conditioner down there in conroe Travis.
47 minutes ago, kenfain said:
Not to mention the skeeters
Oh yeah!! Lately the county has been flying the C130 Spraying. So in 60 years I'll have some form of cancer or disease that i can make money off of by suing them! Lol :)
Last winter, we bought a little 5x5 greenhouse to keep our plants in, in the day time, it would get in the upper 90's in the green house, but the humidity was soo thick, U cant breath!
On 9/23/2017 at 1:25 PM, Travis said:
Man, your Stylin'!
Good for $40! How far ahead can you see with them?
Is that a full cab enclosure?
I can see about like a car with these and cab has he solid doors as well.  Even has a heater although it won't get you very hot.
  • Popular Now
    • By MilSurpYinzer
      Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
      Vehicle is a Kawasaki Krx 1000
      I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.
    • By Timbo
    • By Sharon
    • By dogfood
      Hello -
      New here - and looking hard at a 2026 Mule Pro-FXT 1000.  My wife insists we'll be going with the Platinum Ranch, because in her words, we already saved $ by not going with a Honda 1000-6.  Ready to pull the trigger on this ... almost.
      We were looking at the factory soft cab, but then realized this won't work with the standard hard top, as the soft cab has dual back windows to accommodate the 3/6 folding seats.  However, we like the hard top.  So recognizing there's a lot available in the aftermarket world, does anyone have suggestions relative to an aftermarket soft cab (sides, rear window, etc.) that will work with factory hard top, windshield and doors - and also allows for a (relatively) simple 3/6 seat conversion?
      dogfood
