Massimo Buck 400
By doncaron
Hello everyone!
First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring. I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
thank you in advance again.
By htrotte
#1 While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
Author #2 Finally got the pictures took. See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at. Any help would be appreciated.
By joel b
i purchased a brand new massimo tboss 410 and from day 1 it wont operate in reverse. When i pop in reverse and give it gas it will die out. when i pop in reverse sometimes in will die right away (before giving any gas) and 1 time out of 100 when i pop in reverse it will operate perfectly fine. and yes, it operates perfectly dine in normal drive H and L. any thoughts?? when i called the dealer i got it from they had no idea.
By Ronald
I just purchased an Axis Pro 750 from Lowes. I have two questions not covered in owners manual. 1: In the glovebox there is a 12V connector, it is HOT with key off, is that for a battery maintainer to be plugged in or what is the purpose? 2: In the instrument cluster there is a digital read out for hours, miles and odometer, there is also a digital readout that is flashing, it can be adjusted and looks like 1 - 24 what is it?
