2012 Cub Cadet Volunteer Throttle Cable
By jertex
I have two questions:
By mike28honda
By Pop Bob
I had been driving for about 15 minutes, everything fine. All of a sudden the engine was surging, losing power, would run with 1/2 throttle or greater and was backfiring badly. Luckily I was close to home and got it back. The tipoff to me was that I thought I was hearing intake noise. Sure enough, the rubber boot which connects the air cleaner and intake piping to the throttle body came loose. Obviously the computer was confused. It turned out to be an easy fix, but this is now added to my inspection list. Just thought this might help someone else.
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
By Stan M
I have a 2026 Massimo 760L and also the Massimo snowblower attachment and would like to do a permanent install on the control cable and switch. Does anyone have a recommendation regarding the routing of the cable and mounting of the control switch?
