By Xov
By Tim n Deb
By GBarney
Recently bought a 2010 RTV 1100 with bad engine. a d1105T out of a toro 5400 just came available locally. Looking for info on if anybody has installed the turbo version of this engine, what challenges/ problems were encountered, how it turned out.
Looks like nobody has any insight. I will complete installation and report back as to how it went, how it works, and what's involved.
By Jon Spruill
By FTG-05
