Tires and Wheels
rocmoc
I ordered a new front rim and they sent me a rim they took off of another machine. You could tell it had a tire mounted on it and was scratched around the edge check out what you order closely. I called and complained and they are sending me a new one but it should have been new the first time.
What kind of tire are they and what size?
General Grabber AT2 27x8.50 R14 95Q 6PR OWL $90.10 http://ssl.delti.com/tyre-pictures/General/GRABBERAT2.jpg
got them $80.00 each plus shipping, 55 to my place, + about 13 each for mounting
Can you take some photos of how you mounted your radiator and stick them on webshots, I think that one of my future mods.
Jeff
Jeff
I posted them on Webshots under 4x4x454 I hope it helps. I also posted some of the Supertrapp 2322775780104282158ftwFdN_th.jpg and the Bighorns 2052796350104282158oqHRYk_th.jpg and a few others. I you have any questions please ask.
Well I've tried for 3 days to order the rim on line, but I get an error message after choosing shipping instruction. Maybe because I'm in Mexico. I guess I have to do it the old fashion way and use a phone. Anyone have instruction on how to use the phone. LOL
:rolleyes: Put your finger in the hole that has the number you want, and using your finger, turn the dial in a clockwise direction until your finger hits the stop, Clockwise means upwards on the left side, Repeat for all Ten Digits. :lol: or tap on the phone hook until the operator answers ............. :lol:
The new not mounted tire (Front Tire) (on the right) is for sale if anyone wants it, $115 from Joyner, I'll let this on go for $80 + Shipping
I'm interested in this. How can I pay you for it though? Since I'm eating my tires lately, I would be great to get this. PM to come.
Thanks for the tip on dailing, I printed it out and stuck next to the old rotary phone. LOL
:D New tires on 11-03-08 :D
They look big on the front, but a little small on the back, but I think they'll do great. :rolleyes:
Took my new tires out for a ride today, cold, 64.8 km 40.3 mi. They seem to perform great, they are a little harder to turn when not moving, larger contact patch, they didn't seem to float around as bad the stockers did, they were smoother, no lugs, I don't think I spun the wheels as much, and they didn't throw rocks as bad as the stockers and what rocks it did throw were small and what little mud I got into didn't get slung as bad. I expect these tires to last a lot longer than stock also. I did some hill climbing and fire roading and no roads and down hills and quad trails.
I give these tires and A+ and would rather have them than stock. I also think they will do better in sand than stock.
Got another deal for someone, at present I have my old rear tire mounted on top for my spare. I like my new tires that are mounted on 14 X 6 in. wheels and would like a 5th one. If someone wants two (2) used rear tires on the 14 X 8 wheels with tubes, I'll trade for one General Grabber AT2 27x8.50 R14 95Q 6PR OWL tire mounted on a stock 14 X 6 in wheel.
The tire in the center, one of the wheels had a rock lodge between the brake and the inside of the wheel. It caused a scratch all the way around and finally caused a shallow dent inwards as the rock shattered. This caused a leak and was repaired using JB Weld epoxy to seal the hole, both inside and out, it worked fine, the tube was put in later when the tire developed a leak in the side wall. Photos later.
Tire shipped to me $98.92
Wheel shipped to me $105.74
Mount tire locally $12.50
Total for (2) used rear tires on the 14 X 8 wheels with tubes $217.16 + shipping.
https://teamjoynerusa.3dcartstores.com/14-x...nt_p_9-117.html
QUOTE (Kinarfi @ Nov 3 2008, 11:09 PM) post_snapback.gif :D New tires on 11-03-08 :D
Went out again today to test my tires :lol: , hah, I went for a ride because the weather was good. Went to a place called 5 mile pass and then went to the top following the ridge, the "road" was mostly shale and very very rocky, the square type, and the tires and the trooper just putted and roared right up. Didn't see any damage from the nasty rocks and they held their traction just great, I like this tires. :rolleyes:
So Koool! I just bought a set of GREAT used 31X10.5X15 rock/mudders tires for the new rims off of Craigslist. They have a little wear but more than I will ever use on the Trooper. I will pick them up on Sat but will not have time to mount them until we get back from the trip.
rocmoc n AZ/Mexico
    • By Duncan
      I have a right rear nut that is stuck on axis utv I have put 230 pounds of pressure on it and still won't budge is it reverse thread or what.
    • By Eddie Kirkland
      I have a 2021 Kawasaki Mule 4010.  I need more ground clearance so I'm looking at 2" lift kit and bigger wheels/tires.  Does anyone have experience adding these items to this model Mule?  Any problems? Suggestions?  Thanks
    • By RickinMT
      So, where do you guys get your spare tires and wheels? And if the front wheel is smaller than the back, which size to you carry as a spare?
      Thanks.
    • By mcow
      I am having a hard time getting an issue diagnosed on my 2017 Mahindra 1000 Crew Diesel. Essentially what happens is you can drive it as normal for about 15 minutes at full speed. It will then slow down by itself to about 5 mph. Then all 4 wheels will lock up. It will intermittently still roll while in neutral but after a while the wheels will lock up again. If you let it sit for a while you can usually get it going again for about another 15 minutes. This happened two times in a row for us and then it wouldn't move at all. I took the CVT cover off (which was a complete PIA btw) and the belt was shredded. At this time I assumed that was the issue. I thought the first time it happened the belt may have just been slipping and then the second time it finally gave way completely. The belt was wrapped around the clutches pretty badly so I decided to take it to a local guy that fixes SxS. He replaced the belt and we assumed everything was ok. Picked it up and the exact same thing happened as before after a few minutes of driving it slowed down to about 5 mph and the wheels would intermittently lock in neutral while we tried to tow it back home. Got it back to the guy that replaced the belt and he admittedly told me he had never worked on this make. He thought it may be one of the clutches but they appear to be working. Anyone have any ideas on what the problem could be?
      To add a little context I bought this used from an individual. He told me everything worked great and it did when I test drove it (obviously not long enough I think I only drove it for like 10 minutes then loaded it on a trailer). This happened the first time after driving it the first 15 minutes from getting it home.
    • By MikeBiondo
      Hello folks,
      I would like to purchase some security lug nuts for the Axis 500, but not sure of thread size.
      Anyone know the thread size and/or can recommend a product.
      Thanks...
      Mike
