Yamaha Rhino media article DANGEROUS
Popular Now
By J Cardwell
2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
By oakhill
When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal. It also is not idling very well. Both symptons appeared at about the same time. What should I look for? Thanks.
By didgeridoo
By Recon Marine
Ran fine parked it in garage and 5 days later would not start or make any noise trying to start. Bought new battery, installed it and still nothing, no noise or anything.
Any idea? I can’t figure it out since when I parked it, it was running great.
By Bigmountainrider
Hi Team,
I'm new to the Forum, and I'm looking for your help. I have a 2009 Yamaha Rhino 700 that has stopped consistently charging. Here are the specs and Info I can provide, the Stator and Regulator are new. The Stator does not have continuity to ground on all 3 wires at the engine bay plug. The stator puts out 15-17AC/V at Idle and 38-39AC/V at 2000rpm at both the engine bay plug and the regulator plug. The Battery regulator plug has Battery DC Voltage, when Running the regulator puts out Charging voltage 13.4-15V. I have upgraded/added ground wires from the primary battery to the engine block, from the stock ground wire bolt on the engine to the Chassis and from the secondary battery to the regulator grounding bolt/ground wire. Now the symptoms are it Charges when first started and will continue to charge while driving or at high idle until the machine returns to idle- it will not charge after that, this includes any RPM. If your shut the machine off and restart the process restarts -it will charge until returned to idle. The Machine has and RM Stator and Regulator and a Kimpex Flywheel. The last time it was driven it had an overheating event- unrelated to charging I think, but worth the mention.
Any thoughts would be helpful, I have the factory Regulator- it was working at the time of replacement- when swapped the same issues occur.
