2018 Cub Cadet Challenger 750 shifting problems
By great8redsfan
By Mark M
Hello, Hope someone can help driver side cv axle broke anyone know of aftermarket ones you can get, I have 40 Hours on the machine and don't want to pay 450.00 for a new one from cub cadet but I can't find anything after market
By Bryan g
We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There is a bulletin Im sure everyone has saw about adjusting shift cable. That dont always fix it. I went round n round with coleman on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair " I told them shift lever does not have enough travel . No amount of cable adjustment will increase travel . I extended lever with piece on flat iron by 3/4 of inch . This gave shifter enough travel to properly engage into gear completely . Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out, grease all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts, brake hose routing , make sure not touching exhaust . These are just few of the more common failures I see .
By tim hughes
does any one else have a slipping belt on the hisun ...i put new wet clutch one way bearing new belt, cleaned primary and secondary and still get slight slippage
