  • Alex changed the title to 2018 Cub Cadet Challenger 750 shifting problems
You probably have too much grease in the primary clutch housing that has the weights. I had the same issue with mine. Over a cup of grease in there! The roller weights in there need to move and won’t if cold due to a cup of 90 weight gear oil. Manual calls for slightly greased with 90 wt oil. I live where it is very cold in the winter. I used moly dry spray instead of grease.
  • 11 months later...
YES!  The Cub Cadet Shifting is a poor design. I understand and sometimes forget that you must have your foot on the brke to shift, but, I is still a major pain, especially while plowing.  I hope they find a better way to shift or my next buggie won't be a CUB...
I have a 2020, when I first got it I WD40’d all the moving parts related to the shifter, even the plastic part that moves with the shift lever.
I've never had a problem since then and I’m thinking the dealers should do this before it’s delivered to a customer.
I Have a 2017 Challenger 550.  it is a piece of S*** it has 324 miles and 112 hours on it and is currently in the shop getting its 4th new clutch that is an average of about 28 hours per clutch.  this machine is not abused at all it is lightly used around the yard and was intended to plow my driveway but can't even use it for that since the clutch system does not allow you to back up any inclines without burning out the clutch and the shifting of this machine is pathetic,  I have been going back and forth with level 3 tech support and they seem to put the blame on me for user error everytime.  I was told today they i should never put the machine in a position where i would have to backup from a stop with any incline (LOL) you pay $15000 for this thing and you have to drive it on flat surfaces.  *********Buyers beware these things are junk**************
 I have I have the same your Cub Cadet 2018 Challenger 750 and I have new shift to put in it and all the new shifter is giving me problems and I found out that if you brake lightly you can go from low high and neutral and if you can't get a past neutral into reverse or Park, brake a little harder and it should go all the way up reverse and Park. Hopefully that helps you out. I took my old one apart and there's only two little pieces in there besides the shifter and a spring into little levers at hit notches.
  • 4 weeks later...
My 2017 750 has the same problems  550 miles 66 hours.  3 chutchs.  muffler broke. seat cracked. won't shift.  now the timing chain jump off recking cam gear and bending the yalves.  the timing chain  adjuster was assembled wrong right from the factory. Sent a video  of it to cub and cub will not help me out.  We have to get the word out to not  buy this junk.
  • 7 months later...
I have a 2022 challenger 750 and most of the time it will hardly go all the way into park and when shifting from park to reverse the gears grind. Sounds  horrible, but sometimes it's fine.
  • 5 months later...
I have a 2018 Challenger 750. I would occasionally have this same problem shifting but could always resolve within a half dozen attempts.
Today was different. After a short run, I was in Reverse, backing it towards the garage. I then went to put it in High to move forward and adjust my angle. While I was able to move it past Neutral and into Drive, the display still showed R. I tried changing gears again thinking it didn’t click into Drive right but when I moved to Low, High admin, and then Neutral, the display still showed a R. Next I put it into park and the display finally changed to P. Now I can’t get it out of Park. No matter what gear I move it to, the display shows P. It will not move no matter what gear I try.
Anyone seen this before or have suggestions? Thanks!
  • 1 year later...
Hello, I have. 2020 challenger 750 that’s stuck in drive. It has been bad since shortly after I got it. It gradually would get more difficult to shift until now it won’t shift. The button pushes in but won’t release. I only have about 150 miles on it and it hasn’t been a rough 150 either. Any ideas?
  • Popular Now
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By brewski
    • By RBonds007
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
