In the case of, for instance my T-boss 410, when placed in neutral and the parking brake off, should I be able to manually move the UTV, or will there be some resistance? I understand they are heavier than a lawn tractor, but when I put disengage the transmission on my Ariens 20hp lawn tractor, I can move it manually. I guess I'm trying to find out if I may have a parking brake issue.
Thanks 👍
I have a T-Boss 410.  I know that when it's in neutral, it will roll on its own when the parking brake is not set.  My driveway has a slight incline, so I need to set the parking brake so it won't roll.
I guess I never tried to push it, so I don't know how much resistance it offers.
After checking the parking brake, I adjusted it a bit and I can manually turn the rear wheels. It sounds like there's a very slight drag on the right rear brake, but nothing that has me too concerned.
I have the repair manual that I downloaded from this site, but I can't tell if there's any adjustment for the rear brakes. I know there's no adjustment for automotive disc brakes, so I will assume that it's the same for the UTV unless someone can advise me otherwise?
    • By TapBoss
      So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
      https://a.co/d/09ACQ191
    • By Eman85
    • By Jeff freeman
    • By Alex
      What’s Included?
      Why the RANGER XD 1500?
      Entry Information
    • By AaronD1982
