By Jay Joseph
I have a 2019 CF Moto uforce 1000 my yellow engine light is on and I bought a diagnostics tool online I plugged it into my machine and it came back with error code O2 sensors so I replaced them both plug the diagnostic tool back in the yellow light was off. I let it sit for two days and now the yellow lights back on and when I plug the diagnostic tool back in it says O2 sensor low-voltage bank two sensor one. Does anyone know what this means? Replace both sensors with new ones. I thought I’d save some money and not bring it to a dealer, but looks like I might have to. I took my machine up to camp and it ran like crap almost like it was getting too much gas. Half throttle it was all right but climbing hills, and going over certain terrain it would just die out
By Sando
By rich isaacs
got a 2019 articat prowler, it will only rev to 3800 rpms then says limited rpms . have switched gauge cluster with another machine. it worked fine in other machine but the other machines cluster and ecm did the same limited rpms.
By KidColeman
Just picked up a 2020 UT400 that my 80 year old father will be driving around the farm. We purchased the machine with a few "issues" and they lowered the price accordingly. Small stuff like passenger size mirror and back reflector was torn off by a Tractor supply employee, which we will order replacements for. Also after further inspection, whoever assembled it did not put a few bolts in the rollcage and aren't in the glovebox, so will be having to order those also.
Anyway, there are two initial things on the UT400 I'm not sure what they are or for. The first, there is a square white electrical connector with about 8 pins hanging form under the middle of the back bed - I don't see another one to match up or plug into it, so wondering if this is pre installed optional connection for like towing around a sprayer? Anyone know what this is? Also, there is a 10 inch black rubber hose that is zip tied to the back A frame on the passenger side. I watched the assembly video and it doesn't mention one, so don't know what this hose is for - anyone know?
Also, has anyone come up with a "fix" or work around for having to have the seatbelts plugged in or even in place? We aren't planning on using them and are figuring just plugging them in and wedging them behind the seats - didn't know if there is a way to just disconnect the "over 10mph gas starving" safety sensor.
Looking forward to seeing how this machine does for my father. I'm thinking about installing a suicide knob on it for easier turning for him, as it's a little stiff (compared to our Kawasaki Mule). Maybe with use it will loosen up some?
By barticus73
I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer provided CFMOTO Uforce 600 at $11,500 out the door. Are there any glaring reasons to go with the Uforce 600 at an extra $1000? Is one model more reliable than the other? Any input greatly appreciated.
Thank you,
Jerry
