2017 Massimo MSU500 Thermostat Malfunction
still waiting on parts …. talked to 2 other shops, both now refuse to even work on Massimo products because parts take so long and if its warrenty, 4 months to get paid is ridiculous .. they wont touch one anymore .. its just sad … Talked to an ATV /UTV engine  Rebuider , he says he thinks one of his rebuilt  Rhino engine would work on it , if not, he would let me return it.. So if this pattern continues,  RHINO here I come
well, when we get both fixed, maybe can go riding together .. for about 30 minutes till they break again ..lol  ….Its really sad, it runs great for 20 -30 minutes.. then overheats and will not cool down  .. also we   have bypassed the temp switch on radiator to make fan run continuously now when key is on .... maybe that will help some by keeping the temps down all the time .. You might consider it too
Waterpump appeared to work before but was weak after new head install.. Did it cause the head problem? who knows?  EVERYTHING is  replaced now.. Got it back this morning.. drove it for about 40 minutes around my yard, but that's only 2 acres.. did not run hot.  RAN PERFECTLY!  has more zip , maybe it was losing compression. .. NOW, with the fan running 100% , the engine seems much cooler and way less heat from behind seats ..  . Tomorrow I ll go to my camp at Whiskey Bay on Sherburne Refuge.. I ll put it to the test there, got about 15 miles of trails to ride for UTV ,ATVs …. HOPEFULLY  I can get another 300 miles out of it …   Any progress on yours?  I would check pump and bypass fan switch.. Good Luck
  • 4 weeks later...
Well fellows, there JOY IN MUDDVILLE TONIGHT.. I ran it all day saturday and half of today.. it was 95* outside.. It ran perfectly, and NEVER OVERHEATED!!!  Finally after months of frustration, and trips to the shop, it is working properly  .. We do have the fan switch on radiator bypassed to run continuously when key is on.. Theres far less heat coming up behind the seats now.. It did develope a small exhaust leak, but I dont even care ..  cheers
Good Luck... btw, took mine out yesterday again to the trails at the River... ran absolutely perfectly .. never got hot at all with fan running 100% now.. and I dont have all that hot engine air coming up behind the seats now..  And it was brutally hot outside. in the swamp .... 96* with a 110* heat index.. ran at least 25 miles... My mechanic did a good job.. hopefully this will end my problems from a couple years ... NO THANKS TO THE "EXCELLANT" SERVICE DEPT AT MASSIMO RIPOFF MOTORS .... ps  I removed the winshield  completely ,,, MUCH BETTER FOR DRIVER
Edited by Joe Breaux
dropped my beer
Well, another weekend of fun in the sun.. right after Hurricane Laura theres lots of mud! and the damn thing did not run hot!!!  WOO HOOO  finally working properly and so far appears RELIABLY!  And once more I would like to give a great big  middle finger salute to the ahos at Massimo Motors Service Dept who refused to help me in any way...
    • By rtate1050
      I know that this may be a bit outside the forum , but has anyone had any experience with all terrain wheelchairs ? I live on 5 sandy acres in Florida and am currently wheelchair bound. I have a power wheelchair but it doesn't work very well on my property . I.m looking at one that has rubber treads like a tank . It's pretty expensive so I was wondering if anyone had any experience or knows anything about them before I pulled the trigger.
      I do have aa side-by-side but can't get in and out.
      Thanks , Rich
    • By great8redsfan
    • By joel b
      i purchased a brand new massimo tboss 410 and from day 1 it wont operate in reverse.  When i pop in reverse and give it gas it will die out.  when i pop in reverse sometimes in will die right away (before giving any gas) and 1 time out of 100 when i pop in reverse it will operate perfectly fine.   and yes, it operates perfectly dine in normal drive H and L.  any thoughts??   when i called the dealer i got it from they had no idea.
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By Jay5
      I’m looking for a quiet side by side for my wife and I. We will do some trail riding but nothing too extreme. We are more geared toward leisure riding since we are in our sixties. We go to Wyoming in the summer and have been looking at the Honda Pioneer 1000, can am defender.
