Thanks a lot!
Hi everyone,
I’m considering installing a soft cab enclosure on my vehicle and wanted to get some insights from experienced users.
I’m particularly curious about which materials hold up best in different weather conditions and how to properly secure the enclosure to prevent leaks or wind noise.
Are there specific brands or models you recommend for durability and ease of use?
Also, how do you handle cleaning and maintenance without causing damage?
Any tips, tricks, or common mistakes to avoid would be incredibly helpful.
