trailer hitch for E1
By Rschrem
By monkthumper
By BigWave
Bigwave
By Mike Jenkins
I replaced the stator and now it will not start (run). It cranks fine, has fuel pressure, but will not fire up. I replaced the coil, no luck there.
By HighSon
This mod is not for the fainthearted, as it requires some basic metal fabrication and welding skills. But the result is worth the effort IMO. I chose an aftermarket Honda Talon windshield based on economy, size, and construction (aluminum frame, DOT glass, folding, windshield). It fits OK, a little narrow at the top, and you need to incorporate the lower section of the original acrylic windshield and build some additional plates, but better than being too wide. If you are wondering why I attacked this mod, it's because mine is driven daily on the street. Tired of fading, scratchy, hazy plastic. Sucks in the rain; sucks at night. Now I can see.
