Starting
T-boss 410
I had it apart last week. I cleaned it up inside, and reassembled it. I checked it to ensure it was functioning properly. I can take is apart again, though.
I'm not sure I understand how this starter works, but it's always engaged with the drive gear. The gear reduction unit is inside the side cover of the engine, on the right side. There's a clutch inside that will only turn one way. At first I thought that maybe something had fallen apart inside the cover when I removed the starter, but there's nothing to fall apart. The only other thing I can think of is that for some reason the starter clutch stopped working. The clutch is behind the generator, and doesn't look like it's too easy to get to. With only 14.6 hours on it, I wouldn't think the starter clutch went bad suddenly.
Could it somehow be operating in reverse of the correct way it's supposed to turn?
I just watched a video of a Yamaha 4 wheeler that was doing the same thing. It had been disassembled and reassembled, and was running backwards. They didn't change anything, but it ran backwards. I could take it apart again, and check it. But I have a question. How do I hold the brushes in? that was a real PITA to reassemble.
 It was working after you took it apart. So I think the problem is with either the new solenoid. Or there's something going on with the starter. Possibly related to the recent disassembling. Probably not, since it was working.
So I'd check voltage again, then put the old solenoid back on it, for testing purposes. Check operation again, see if it made a difference.
But if everything else checks out, I'd take it apart again. Or replace it.
Dunno how they managed to make it run backwards. Sounds like a case of reversed polarity. Maybe put the magnets in opposite?
Whatever the reason they had that problem. I don't think that it's what's going on in yours. Mostly just because it was working before.
Maybe try giving the starter a light tap.
33 minutes ago, Travis said:
I finally found them, service manual for the t-boss, $75... it may be worth your money, if you plan on keeping this machine https://www.scautosports.com/Manuals/Service_Manual_TBoss410
Thanks, I appreciate that. I saw that before, but was hesitant about buying it for that price. I had read a post about it, and the fellow who bought it said it was a gross waste of money. He said it didn't have much information in it to justify the cost.
I already tapped on the starter. I am convinced that it's running backwards, but I will put the old solenoid back in and see if that makes a difference. I tested both for resistance, and compared the numbers. The new one has less resistance. I know I wired it correctly. I was very careful about that.
If it was starting, and all you changed was the solenoid. I see absolutely no way for it to suddenly start turning backwards. But then, I can't see how it would turn backwards anyway.
I could see how something could've broke inside the starter though. Something that attaches the shaft to the gear maybe.
Only one way to find out. But I'd still give it a chance to be something simple. Like a new solenoid that's bad right out of the box. Especially since that's a ten minute test, where you don't even get dirty.
Well folks, I was correct. The starter was running backwards. Don't know how or why, but I disassembled it and turned the housing and tightened it back up. Had to do that a few times, but it finally spun the correct direction.
I still hangs up a bit on the compression stroke, but it starts much quicker now.
Do you all think that it's back to replacing the battery?
I don't understand it, either. I checked YouTube last night, and there were several instances of the starter turning in reverse. With most of them, the fix was to disassemble, check the brushes, etc. One mentioned to be sure that the casing was replaced in the exact location that it was removed. So I disassembled it, turned the casing (talk about a PITA), and tried it. Still turning the wrong direction. Did it again, turning the casing, and this time it spun the correct direction.
Don't know how to explain it, but it worked.
Just an update. Hadn't started the UTV since my last post (01/10/2021), so with crossed fingers I tried today. Starter spun over like it should, started right up and idled smoothly. No problem with compression stroke or anything.
I guess it was the solenoid after all. Only thing I can come up with, since it started so easy. It's never done that before.
    • By donwan
      I have a part that fell over to the exhaust and burned the harness up. I can't figure out what it is. Does anyone know what the start relay looks like? The part I can't figure out has 4 wires, a red power, a green and brown wire, a black and unsure what the 4th color was. Anyone have a clue?
    • By AndySwish33
      Brand new t boss 550. couple of questions.
      1.  Do you need speakers in order to play music ?  Hooked my phone to Bluetooth no sound
      2.  On screen registration.. it won’t let me fill in the info on the touch screen.  Navigation works but the registration portion does not
      3.  Is there a data plan you can get or need ?
      thanks everyone
    • By MOTORHEAD1959
      ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
    • By malenurse13
      We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
      The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
      THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
      Thank you!
