Hinged Hoods
By Karlibob
I have a 2020 800 sx with about 16 hours on it. From day one I have heard a clunking noise from the front end going over bumps. Has anyone else experienced this? Also this past weekend while out riding I heard a noise that sounded like the dump bed bounced three or four different times, again has anyone experienced anything like that. Thanks, gary
By Robbie Wyre
I'm working on a 2005 Cub Cadet side by side and I'm trying to remove the front two axles. I have a slide hammer puller on the inner joint and with all my strength they will not budge. Anyone have the same issues and is there something I'm missing or a trick of some sort to pull these out? Any suggestions please and thank you.
By SouthernGypsy
By KimAC
-Kim
