whassup
Popular Now
By MilSurpYinzer
Anyone decent with electrical work that knows a good tutorial on how to make my running lights switch off all together but also turn back on when I need too? I'd assume that my lights are hard wired to the battery or the fuse panel.
Vehicle is a Kawasaki Krx 1000
I'm looking to ad IR driving lights for night vision and short of just putting black tape over the lights I feel this would be a more efficient option and it would be cooler.Â
By kmiller7351
Trying to get running a 550 Colman running but I think head gasket went bad. Do i just replace with new gasket, clean up and replace or is there more to it?
By CraigL
I have a 2016 Landmaster 670. It will stop running after 15-20 of driving. Restarts easily but still has a hard time staying running after that. New carburetor, fuel pump, fuel filter, and spark plugs. Anybody else have this problem?
By Robert301972
I just bought a 2012 can am commander xt Rotax 1000 4x4 EFI. It has 456 Hours on it and 6543 miles on it. From what I have read that is not a hole lot. It will start Right up run for about 5 or 10 sec then starts to stubble and then stalls. And ever time I start it It runs fine for the first 5 or 10 sec. I can Repeat the process for about 8 or 9 times and will will at least stay running. But it does not run fine until it is warmed up. Once it is up to operating temp it runs and drives fine. I have Replaced the fuel pump. Thinking that was the problem but no. I replace the map sensor It wouldn't even start with the new one in. So I put the old one back in and it started Right back up. I Think I had a bad map sensor. I will get a different one. It Is definitely a fuel problem. I just don't know what kind of problem. Here Is my thinking on all the sensors. (Crank sensor) all that does is send a single to the coils. That don't care if the motor is cold or warm. (Map sensor) all that does is measure the temp of the air.(Fuel Injectors) If they were bad it would not start at all. If they were clogged. It would run like shit if it was cold or warm. (Temp sensor) This is the only sensor that tells the computer weather the engine is cold or warm. So what is the temp sensor is telling the computer that the engine is warm. When I first start it. the computer will think that the engine is at operating temp. So It leans out the fuel mixture. So with a lean fuel mixture going into a cold engine. It Is going to stall. I have no scan tool to hook up to the computer. So Please help. I am at my wits End trying to figure this thing out.
By timotara
Have a Coleman 2021 ut400rt 234 miles on it purchased last year from a person who won it in a drawing,p was not giving away until 2024 late, did not realize the running lights not working checked all fuses everything good double filament bulb one filaments light up with brake, turn signals fine front and rear headlight everything okay just no rear running lights, could it be in the light switch, thank you in advance for any help
