I've always been kind of a pirate when it come to the internet by taking the info I need and then leaving nothing behind. I figured it was about time to start contributing to the comunity and participate. I must admit I have been reading a while and would like to thank everyone for the postive influence and help making an informed decision with my T2. It's nice to know that there are people out there what will respond to problems without biased opintions. As I'm sure you are all aware this is pretty much the only resource other than your local dealer and the Joyner USA website. I really appretiate the fact that you guys have started organizing things to make this an even better place for info.
So thanks again and I look forward to your insight in my posts!
Chris
  • Popular Now
    • By BWF
      I am at a loss, please help!
      Brad
    • By Eman85
    • By Jeff freeman
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
