new UTV owner
By Xov
By Tim n Deb
By Gerald Dillman
By davebuckholts
I just picked this UTV up off of Marketplace. It needs batteries.
I am installing a single 48v lithium battery.
The on board charger, a NOCO Genius GX 4820, has a lithium mode.
Has anyone here used this charger on new lithium batteries? I want to be certain of the compatibility before hooking the charger to this expensive battery. **
I got in touch with NOCO and they told me the charger is fine to use on a new LiFePo battery.
Nice charger. Many modes. New ones are running about $550.
By CYJSP2009
Dear Joyner owners
3. Cables,
4. Brake parts
5. Engine parts
6. Other parts.
Have a good weekend
Casey / Leaf Asia
2023-11-17
