Seriously considering buying 2022 Axis 700 from Lowes… any regrets from current owners?
Go to solution
Solved by Robert Scott,
By Buddee
Any help appreciated!
By great8redsfan
By Ronald
I just purchased an Axis Pro 750 from Lowes. I have two questions not covered in owners manual. 1: In the glovebox there is a 12V connector, it is HOT with key off, is that for a battery maintainer to be plugged in or what is the purpose? 2: In the instrument cluster there is a digital read out for hours, miles and odometer, there is also a digital readout that is flashing, it can be adjusted and looks like 1 - 24 what is it?
By todd93
Hi, all! I. I'm new to the board, hoping someone could help me out! I have a 2020 Hisun Sector 550C that I bought new in 2021. Today, I took some stuff next door to my parents. When I went to leave, I turned on the key, heard the solenoid click, but no lights, no guage activity, no fuel pump, and no starter.
The battery is good, I checked all the fuses, they are good. Not sure if the relays are good, or even what to look for there. Is it possible that it's maybe a wire?
I'm really stumped on this one! Any help would be deeply appreciated! Attached is a pic of the fuse box layout.
Todd
