Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
New to this site I just got this 2014 Coleman UTV 700 High Temp Light on from the start cold I haven't really ohm checked the sensors although they are all new but I have done lots of work on the engine I've replace the head gasket, wet clutch rebuilt the primary clutch and cleaned the secondary clutch with a new belt plus a bunch of other stuff I just can't figure out this high temp light that is on at start and has never been off. I have bled the air multiple times. I also wired a switch for the fan to run it most of the time due to others that have suggested this. It is running good the radiator is getting warm but really haven't ran it enough to make sure it's not getting too hot but I just want the light to work as it's suppose to. I would really like to install a true temp gauge if anybody could help with doing that.
I have a 2020 Sector E1. It's been a great UTV over the years and I did a lithium battery upgrade a few years back (complete game changer). Since owning the unit the dashboard and lights would occasionally flicker while driving, but not every time. I couldn't replicate the issue in any driving scenario and all fuses are good. The dashboard and several switches finally died completely this past weekend - meaning lights, winch, and dash lights do not work, but forward/reverse and speed work. I rechecked the fuses and all look good - any ideas on what else to check?
