2022 Hisun 750 EPS Overall very loud while driving
By Prepper
I have been doing a little research on which engine oil is best for UTV engines. There seems to be some disagreement over using a good quality regular engine oil, and the necessity of using "M2" (or wet clutch suitable) oil. My understanding is the "wet clutch" suitable oil has less friction reduction properties (hence a more responsive clutch with less slippage). While less friction reduction properties would seem to be better for the wet clutch... it would not be best for the internal engine parts like camshaft bearings and other moving parts where friction is detrimental and would lead to premature failure. Some folks swear you need M2 oil, while others say they have been using regular motor oil for years and their clutch is just fine. Could they both be right ???
Any thoughts ?
By LeMay624
Hey guys! Was wondering if anybody has had any experience in shutting up a Kioti K9 or Kioti Mechron. I daily drive a K9 in an underground mine and between the engine noise and belt whine I can’t hear myself think while driving this thing! 2-5 hours a day. It’s a 2021 model with 180 hours on it. Belt and clutches are clean, machine is maintained to factory recommended schedule and then some. Has been like this since new. Before I start boxing in the engine with plywood and stuffing insulation under the seat I thought I would reach out and see if anybody has run into this before!
By JimG
By Jacob E freeman
