Bought my 2009 Yamaha Rhino, (fuel injected of course), recently from the original owner. Only had 500 miles and 70hrs. Starts reliably, however, it will not idle but about 50% of the time. Also, when driving slow in low or high, that is to say, relatively low rpms and below about 10 mph, it bucks and almost wants to die..... not smooth at all. However, at speed (say 12-15 mph or more) it runs very well, like it should. Any ideas?
Does anyone know where the winch fuse is located on a 2021 ut400? I’ve been working on the solenoid because the winch will only go in one direction..
Either in or out depending if I reverse the leads on the solenoid. Now I have no power to the solenoid and it appears I blew a fuse. Winch is supposed to have a 30 amp fuse.
i checked all the fuses in the fuse box near the battery and the 30amp fuse hanging in the compartment. Everything is good there.
but I can’t locate any other fuses. Any help would be appreciated.
I have a 2020 Sector E1. It's been a great UTV over the years and I did a lithium battery upgrade a few years back (complete game changer). Since owning the unit the dashboard and lights would occasionally flicker while driving, but not every time. I couldn't replicate the issue in any driving scenario and all fuses are good. The dashboard and several switches finally died completely this past weekend - meaning lights, winch, and dash lights do not work, but forward/reverse and speed work. I rechecked the fuses and all look good - any ideas on what else to check?
