Recently acquired a 2014 Coleman/Hisun 400 outfitter, not running. 37 hrs on meter 165miles.
It will crank fine but I'm not hearing the fuel pump run when turning the key. The fuses are fine. Also I am not getting any spark out of the coil. Replaced coil no change. I was wondering if the ECM might be causing these problems or where to look. Any help would be greatly appreciated.
  • Alex changed the title to 2014 Coleman/Hisun 400 outfitter starting issues
    • By Tim n Deb
    • By monkthumper
    • By BigWave
      Bigwave
    • By Ed Michael
      Subaru SxS.mp4
